Blocking and preventing changing mobile data / mobile hotspot
Utelias
Here's what I'd like to do: schedule a block that turns off mobile hotspot or mobile data for a chosen time and prevents turning them back on before a set time. Can you recommend apps for this (or perhaps some other forum to ask for help)?
Using a Samsung S3 with 4.4.4
as if you are using 4.4 .4 android device you cant change sim 1 to sim 2 for preventing it will ask you in starting if you format it
Welcome to Android Forums.
The following Tasker profile will turn mobile data and WiFi off from 11:00 to 11:15 and then turn it back on. WiFi cannot be turned on/off this way after Android 5.0.
Profile: Data Toggle
Time: From 11:00AM Till 11:14AM
Enter: Anon
A1: Mobile Data [ Set:Off ]
A2: WiFi [ Set:Off ]
Exit: Anon
A1: Mobile Data [ Set:On ]
A2: WiFi [ Set:On ]
More information can be found in the Tasker sub-forum of this forum.
... Thom
I think that will require root-ing the phone.
On an un-root0ed phone pulling the SIM would stop Data but also stop Voice and would not stop WiFi.
... Thom
