Help Blocking Mode question
darkcyber
Android Expert
Is there anyway to block calls or text messages from a single contact? It seems, from what I can tell, Blocking Mode will block everything except for allowed contacts. It would be much better if you could block specific contacts.
Blacklist allows you to block particular numbers or wildcards (like numbers starting with 800). You can also long-press a number in your call log and add it to the reject list.
