Upgraded to v2.2.1 a few weeks ago - everything has been great, really pleased with phone.
Used the phone yesterdy, no problems. Switched the phone off and put it on charge last night - this morning, the phone would not turn on - hung on the "S" logo for a couple of minutes and then went blank. tried all sorts but no luck, so had resort to a factory reset, which of course deletes all data/apps etc.
A real PITA when you use it for business - the phone is in a basic state with no apps - really don't have time to be messing around with it get it back to its previous state until the weekend.
Sometimes i really do think about throwing it in the bin and getting something a little more robust!!!
Anyone else experienced similar problems - (I haven't searched to see if anyone has, I really don't have time)
not sure you didnt forget to add the FC vibrate sounds
. And I am waiting when it happens again. if you would search the forums you would find out you arent alone. Only thing you can do. always have a good backup
