Blu Studio X Plus Boot Problem
I bought a Blu Studio X Plus couple months ago and since then, I have been using it with no troubles but just recently it developed an issue of booting and not getting to the home screen but rather booth and ends on the colored screenand reboot again and end on the same picture.
on the first day and first time ever that the issue occurred i did hard reset and there it was working again.
And now after some couple of weeks it is back on it again "hahaha" i laughed thinking i can still just trash the problem like i did last time but the same method i used which is hard resetting seems not to be doing anything.
So, can anyone help me to fix this boot issue or some one know the issue that the phone is having he should just tell me i will be very glad to hear.
Really thanks in advance!
I would worry that it is a hardware problem since a factory reset didn't solve it. Since you have only had the device for a couple months, is there any chance that they would replace the device for you? If that's an option, I think it would be the best one.
Also, a factory reset only removed user data and settings, and does not actually reset anything on the system partition. You might consider attempting to reflash the stock firmware to the device if it's an option. I'm not familiar with this specific device so you will have to be extra sure that you are installing firmware meant for your specific model.
A few places to start looking for firmware:
http://androidforums.com/threads/blu-studio-x-firmware-d750-lollipop.955201/
https://plus.google.com/communities...5/stream/aff5d54f-92d5-48f2-816e-ea4a74337894
http://android-recovery.info/1439/firmware/Blu/Studio+X+Plus
http://www.stockrom.net/2015/08/download-stock-rom-para-blu-studio-x.html
http://www.blu-dev.com/roms
http://www.needrom.com/download/blu-studio-x/
