BLU Tango USB drivers
gyasi8
hi i can't seem to get my BLU Tango to install when i connect it via USB to pc. I point it to the Google USB drivers but Windows still doesn't recognise it.
It comes up in device manager as Android device with a yellow exclamation icon.
Anyone know how to fix this. I really wanna do some dev on this phone
go to the option opening bar thing like = that on phone and click on the usb connection and click on the android to disable the sd card on your phone and then it will open the sd card on your pc. (well it did on mine anyways)
I think you're mistaken about my problem. I don't want to use the phone as a USB Storage device. You don't need drivers for that.
However to do USB debugging on your pc, the USB drivers are required and that is why I am looking for those drivers
If anyone has or knows where to get those drivers please help me
