Root BlueBattery (StatusBar)
corcor67
This is a blue battery set I made, hope you like!
White Percent Added
Full set including charging
Download Plain Blue here: BlueBattery.zip
Download Blue With White % here: http://www.mediafire.com/?dqytnwzfzhw
To use, my preferred method is to grab the theme file you're using (or rom if you don't use a theme, and overwrite the files, they are named correctly so you only need to drag and drop to system/framework/framework-res.apk/res/drawable-hdpi. Then re-install the theme.
Feel free to use, if you use in a theme or rom please just give credit where it's due. If you want to donate, heres the link ( https://www.paypal.com/cgi-bin/websc...=6DC6G9VW4W7EW )
Other colors will come, requests are welcome!
