Hello,
I have problem with using RAM Expander application, it shows me error message that my kernel does not support using swapp file..
So I contacted developer and he told me that I should switch to cyanogenmod, well I have B3000 (chinese phone), and for this device there is no support.. And I think that if I install this mod I will loose my application for Analog TV tuner (and I can not find that one anywhere to download), and I have double SIM, So I also think that I will be able to use just one SIM card after I flesh my phone, (if I install ROM for some other device , if that is even possible)..
Anyway, if anyone have any suggestion I will be very grateful!
Regards,
Boocy.
Regards,
Boocy.
, but welcome to the forums
