Help bluetooth and handsfree problems
zlod
i've got a galaxy apollo with 2.2 on it
i'm trying to connect it to a built-in bluetooth handsfree kit (actually via the radio) in the car
the problem is that the phone will connect, will take one call and then will drop the connection immediately afterwards.
the only way it will re-connect is if bluetooth is turned off and back on, then it works thereafter without problems.
any ideas at all as it's a real nightmare at the moment
thanks in advance for any suggestions
Are you charging your phone at the same time? I think thats what my problem was as I noticed a pop up box on my screen saying something along the lines of to use USB connection you must disable blue tooth with a yes or no option. If I ignored it the handsfree wouldn't work, but if I press no it stays connected, so hopefully I've resolved my issue.
i hope it solves things for you, although i've not been charging mine during the problems ... it's a headache
