mistergoof
Member
In my new car Honda CRV (UK version)
I use the 3.5 mm jack to play music through the stereo and also bluetooth for phone calls
With the 3.5 mm jack plugged in an incoming call does not root through to Bluetooth, until I pull out the 3.5 mm jack then I can quite happily talk.
Is there a setting that I can set so that the music goes out through 3.5 mm jack but calls still work through Bluetooth?
