Scootmien
Hi all
Some time ago, I downloaded the Bluetooth and Wifi Unlocker by Joel Stern from the Google Play store for my HTC One. I liked it so much I bought the license key to upgrade it to the paid version and it's worked completely flawlessly since then.
However, now I have a Galaxy Note 3 as well as the HTC so I naturally wanted to install it on the new device too.
No luck. Google Play says it is incompatible with my current phone (running Android 4.3) as the app is only compatible with 4.2 and below. Interestingly, although my HTC has recently been updated to 4.3, the app continues to work perfectly.
Can anyone tell me a way to fool Google Pay into allowing me to install it on my Note 3 from there please? I dislike using third party sites to download apps as you never know what you are going to actually get.
