Help Bluetooth Audio volume low
M
mbailey
Guest
My X10i has really low audio volume when using my bluetooth headset.
The same headset when paired with my old trusty Sony Ericsson K610i worked fine. I have also tried with a Sony Ericsson Elm and that was ok.
Is there anyway to increase the volume on the X10i?
Any Sw patches, apps or tweaks?
I have the same problem with my Clarion stereo in the car, have to turn it up to 40 to hear streaming audio, then it blows my ear drums if anyone calls, any ideas?
same issue - i have sont BT Headset, very quite by default, but fine once ive turned up the volume..
didnt need to do this on my old w595. Maybe the R2 Will fix, ive updated but not yet tried BT
Have you turned up the volume on the X10 itself while using Bluetooth? It's called "Bluetooth media volume" and it's separate from "Media volume" (speaker) and "In call volume". If you have a volume control on your Bluetooth device, then this is separate as well.
