jetsfan2014
I tried to pair up my new G3 to my car just a moment ago, but was unable to pair successfully. Anyone else have issues with that?
I was able to get my phone to pair but it doesn't connect automatically when I turn bluetooth on. I have to open my bluetooth settings and select my car from the list of devices. My GNex would connect automatically when I toggled bluetooth on so this is kind of annoying.
Thanks for the update guys. I have Verizon and after multiple tries this morning it finally linked. I had to unpair my other phone for it to finally connect.
Same here. Minor inconvenience as I will simply do it before beginning the drive but it is weird.
Make sure you turn BT on before you turn the car on. The car system should send a connection request to the phone when it's turned on, but if BT on the phone is off it obviously won't connect. Mine auto connects fine as long as BT is on first.
Hi .. Yes done all that...even took the dame stereo out of the car to reset it.. But still the same.. My next plan is to try my phone in halfords on the same brand stereo .. .the annoying thing is even my father in laws phone (HTC )works fine in MY car.. Not giving up!!!If you haven't already, try deleting the car from your phone's BT device list, and delete the phone from your car's BT device list, and start over pairing the two devices.
Maybe the app TASKER will do the trick:
http://tasker.dinglisch.net/
https://play.google.com/store/apps/details?id=net.dinglisch.android.taskerm&hl=en
