Bluetooth connection problems
AfroSheen
I have a profile called Bluetooth Truck. The state is: Bluetooth connect. When I'm off Wifi the Bluetooth Truck profile will connect the first time. When I get to my destination and shut the truck off, of course the Bluetooth Truck profile connection will stop.
When I get back in the truck and start it up the truck and phone is connected, but the profile for Bluetooth Truck does not show active. The only way is to close the Bluetooth connection and restart it. Then select the Bluetooth connection {Sync} then the Bluetooth Truck profile will connect.
The enter tasks and exit tasks is: Say "Truck Connected" or "Truck Disconnected". Just something simple.
I can't figure out how to get it working after Bluetooth Truck profile has disconnected.
Thanks in advance for your help.
On exit, Net->Bluetooth Set Off, wait a few seconds, then Net->Bluetooth set on. Let Takser do the reset for you.
