Hi there, had my Hero since January, but only just purchased a bluetooth headset for use when on motorbike.
The problem is, when recieving a call, there is no audio through the headset unless i manually select (menu/bluetooth on) from the options when in a call. Also, o cannot seem to find a auto answer option, only able to manually answer a call via the handset, which isn't much good when on a motorbike, obviously.
Thanks for any help.
