I have Bluetooth turned on on both my Galaxy S2 and Galaxy Tab 2 running Jelly Bean.
The Bluetooth icon shows in the notification bar a shown and both are shown as paired in Bluetooth settings; note the icon on the Tab 2 seems to be "illuminated" whereas the icon on the S2 seems to be visible "greyed out"?
I open ES File Explorer and select a file to transfer from Tab 2 to S2. The using More > Send try to forward this jpg file. Scanning occurs but no option to use Bluetooth appears. A message saying please check wireless settings etc ends process.
Does not having paired devices with Bluetooth turned on mean that file transfer should be automatic?
Any advice please?
Any advice please?
