Help bluetooth issue
Lohung
ok so i turn my blue tooth on on my phone, then i turn my bluetooth on ( i have the motorola Elite flip). I can get number dialing and such but the phone calls will not go through the blue tooth. so i try reversing the process. Bluetooth on first then turn it on on the phone.. still nothing..
and this seems random cause sometimes it works... does anyone else have this problem at all????
I've had the occasional issue with bluetooth. Sometimes mine won't connect, typically after a period when I've had the phone on airplane mode. When this I turn bluetooth off and then back on but it typically won't turn back on. The only fix I've found is to reboot the phone and then it works every time.
