mymailbox771
Software version 1 July 19 update
Issue - certain devices will not work with bluetooth.
Process - item is paired via bluetooth but doesn't connect to app. Remove device to re-pair and the phone cannot connect to the device on subsequent retries.
Effected items - samsung gear vr controller, mgcool band 5 (brand new)
Samsung gear VR controller (bought a new one to replace), was then able re-bond the original which I thought was dead. It then worked for a while then dropped off and won't rebond.
Mgcool band 5 - bonded, wouldn't talk to the app. Removed from bluetooth then attempted to rebond and won't rebond (cannot connect to bluetooth device: even though it can see it).
Actions - I've cleared the bluetooth cache, restarted and nothing changed. I've even removed devices I don't use that often just in case there is a limit to how many devices I can have paired.
HAILP.
HAILP.
