Bluetooth Music
magdelphi
Member
Listen to music on all your Devices Bluetooth and shows battery level.
The Bluetooth Music app allows you to listen to music and audio files on all Bluetooth audio devices, even those that don't normally allow it, like all those that only work during calls. If the headset is A2DP profile, you will be able to listen to music in good quality. The widget controls the switching of Bluetooth sound modes.
You can also use it on some car radios.
Google Play https://play.google.com/store/apps/details?id=blue.music.com.mag.bluetoothstereo
  • Bluetooth_MusicV03.apk
The program facilitates the connection of headsets and allows dynamic switching between headsets. There is an audible alarm to connect the music mode.
In the plans I will add an indication of the battery charge of the Bluetooth device.
I think this is a necessary functionapp.
That's a useful feature, though as of 8.1 it's a standard Android feature as well. But of course many devices will never get 8.1 or later.
If our Lexus is anything to go by - you don't need it. The damn car audio is set up to grab MP3s from wherever it finds them and play music first.
We just went through this with a 2013 Lexus and a flip phone. A Lexus tech finally admitted that the car audio is set up this way. Car comes with a trial of Sirius Radio and I'd bet Lexus gets a kickback if you subscribe. The Vulcan told Sirius where to go as he doesn't want it. If you do use a true "smart phone" you can get the car system to ignore the music on the phone.
The tech told me that the ability to remove audio from any bluetooth device in the car system was just made available this year. Bluetooth Audio (at least on Lexus) covers the phone as well as an audio player. The full solution is NOT in the manual.
The main task of the application is to connect with the Bluetooth audio devices, the indication of the battery charge is the right option. If you want to display all devices, try an app BatON
If the headset supports the transfer of parameters, starting from the shows the battery level.
In pay version support Smart Weach as headset for listen music.
