Help Bluetooth notworking
Just tried to use bluetooth since i flashed vampirefo's 2.7 kernel and FroyoRC2. Not working. Have Quick Settings app and it didnt work so tried the default settings menu. Didnt work either. Cant get it to turn on. Any ideas?
are you sure you have the 2.7 kernel?
2.7 fixed Bluetooth, any other kernel doesn't have Bluetooth functionality.
You may want to try and reflash 2.7 or flash the OC or LV kernel since their 2.7 based and it may fix it.
Did Vampirefo make an overclock version? Or is it someone else's based off it? I though he hadnt made an overclock kernel yet. How stable is it? And I reflashed the kernel and it worker. Thanks
