Bluetooth Pairing Made Easier?
xuohtx
I am looking for a way to create a shortcut or perhaps an App that will allow me to pair/connect with devices easier.
I hate that I have to go through the following path to do this: Menu/Settings/Wireless & Networks/Bluetooth Settings/Select Device. I would love to be able to add a shortcut on my homescreen that would allow me to pair with a specific device. Or maybe a widget that lists your devices so you can just tap the one to connect with.
My car will connect automatically but other devices won't. Any help here?
I'm on a rooted HTC Eris, so not sure if we have the same settings, but try this.
Long press on a home screen (or whatever it is you do to tell you phone you'd like to add something to your home screen) select shortcuts > settings > bluetooth settings.
That will give you a shortcut to the screen where you pair & select devices - cut's out a fw steps anyway.
Thanks mhotovec, that is a little better but I wish there was a way to to take it a step further and have one touch pairing from my homescreen.
