Anyone else have a bluetooth problem since the 4.4.2 update? I use my N7 as my music player in my Ford. Ever since 4.4.2, every time I start vehicle it disconnects. I have to go into bluetooth settings and reconnect only it will do this 4 to 6 times until it stays connected.
Mine has a similar problem, but I'm on 4.3 on the s4
I get into the car, and it never connects on its own. It seems to have something to do with the Bluetooth 4 device I have (a smart watch). When thats not installed, it works fine. Almost like its screwing up the normal bluetooth.
I've also found that when you do try and connect, it will connect, start playing, and then drop off. Sometimes this can go on several times before it finally connects (each time I have to manually try and reconnect)
Getting pretty annoying, and my smartwatch is pretty much useless
