Bluetooth Q's
PittCaleb
I use bluetooth all the time in my GM with OnStar. On any other traditional phone, I can press the BT button in the car, state "Bluetooth" then "voice" and I then have voice command of the phone where I can say things like "Call Darren Mobile"
Using OnStar, bluetooth/voice gets me the response "your phone does not support voice commands."
If I press/hold the spyglass, I can do these things and they tend to work. Thoughts?
Note however that with BT pairing, I can use the saved numbers inside of OnStar and it does successfully pass through the dialing instructions using the phone book in the car (limited to 10 or so names/numbers).
Which lends me to this - it appears that while BT paired, the audio from the phone is sent through BT and thus there is none on the phone itself. I noticed this while attempting to use the navigation feature. Since the phone is paired, I get no audio. Turn off pairing, I get audio. Any way to change this 'feature'?
Thanks in advance,
PittCaleb
