If your running a stock rom, I believe it should. If not you could try different music apps. My preferred is PowerAMP. The bluetooth on some roms doesnt work correctly, all you will hear is faint static.
i was able to figure it out. i was using the sense rom and that doesnt allow the bluetooth controls. i switched it to the teamchickeneater rom and now it works perfectly
