Hi all,
I've been setting up my unrooted Galaxy S3 with Android 4.3 to allow turn by turn navigation on a motorcycle. I have a helmet with a bluetooth headset, through which I want to receive the voice instructions.
The issue I am facing is that the headset volume, when the GPS app gives a direction, is low for 2 to 3 seconds, after which it resumes at a normal volume.
This means that due to wind noise I often miss (part of) the instruction.
Is there a setting or app that overrides this low volume startup? I have used the same headset with a Galaxy Ace 2, in which this problem does not occur, so I cannot imagine it's the headset's problem.
It also happens when the phone starts to play music.
When playing music, the GPS directions come through at normal volume, so I *think* it only happens when the headset is activated..
Any suggestions? Thank you!
