Help Blurry pictures
teamevo88
I just got this phone and I love it so far. Only problem is the camera. My pictures always look blurry. From a google search I found out Camera ICS would be a fix but it still is blurry. Any other fixes?
Have you updated the firmware on the phone, I remember seeing that one of the updates was something to do with the camera... always found my camera to be perfect, never had a blurry photo yet even in bad light or in the car.
Just got the phone yesterday but I could check firmware...
Maybe you have set a filter option.
You might go in the cam's settings and set all to default.
Harry
Your phone's pictures are blurry because you most likely have flash on completely. Yes, I made this dumb mistake as well. Make sure that the "A" icon in the top right corner of the camera app has a lighting bolt beneath it. Happy shooting!
