Help Blutooth keeps disconnecting. Jabra Freeway.
steveo42
When using my Jabra Freeway with my Razr Maxx and Google Navigation, I keep getting "BT disconnected" "BT connected" messages. Also I seem to need to power off and on the Jabra to connect when it loses the connection completely. I have no problems using my Blackberry paired to the Jabra. One other thing, with Google Maps I can only adjust the volume using the Jabra Vol+/- buttons when Google is "talking". If I hit Vol+ it does nothing unless Google is giving directions. Again the Blackberry works fine.
Any ideas?
Similar problem here with my Galaxy 3s. Worked perfectly for two weeks...then started disconnecting. Need to re pair every time I get into the car!
Something changed....but I don't know what. Help would be appreciated
Do you have your Wi-Fi turned on? If so try cycling that off or off/on and see if it helps. Oddly enough sometimes cycling Wi-Fi or Bluetooth seems to make the other properly function.
