Here is a little trick I discovered recently. If you have a later model BMW with the USB port that you would either plug in the iPod connector or a USB stick, if you plug your Incredible in you will be able to charge that phone through the port, negating the need for a separate cigarette lighter charger. This may work on other cars with a USB port, but your mileage may vary.
Additionally, you could set up your music folder and playlists directory on the Incredible's internal storage to use it for music playback. Unfortunately on my 2008 X5 with the "single button" iDrive, it only reads the internal storage memory, and not the SD card.
