Help Bookmark help please
On the browser there is an x in the upper right side which turns into a bookmark symbol once whatever page you are loading is finished loading. You tap that symbol and it will bring up your bookmarks.
Hope that helps!
You can save a bookmark to your home screen. Long press an empty space on one of your Home screens...choose "Shortcuts"..."choose Bookmark"...then choose of one your saved bookmarks.
That's also how you would add a contact or a direct dial shortcut (speed dial) to your home screen. Just choose contact or direct dial instead of bookmark.
I find this ^^ to be the best way to do it. Saves you from having to download any special apps. :D
I find Bookmark Tree manager very handy, either as a link in Dock or on Screen. It uses bookmarks from default browser, and/or you can add your own, make your own categories etc:
