To answer your question, yes you can use winamp to listen to podcasts. You have to setup everything using the desktop version of the software, not the phone app. Not going to go into details on how to set everything up, however, I can tell you that its free to download. After you setup everything as you want it, you can sync your phone with the desktop either wired or wireless. Hope this helps.
