Help Booooooooo my x10 wont charge
aderuk
plugged in last night and would not charge up, either by pc or wall socket ,the charging cable when plugged in at the x10 end is wobbly,only had 9 days but 02 are sending out a new one for me monday is this a common problem?
I had problems with un-original chargers. And it won't charge with the PC off, ony on even though the USB on the PC has power when off. I charge the mouse there. The X10 seems to be picky with chargers.
As indicated in the manual, it can take several minutes (after plugging in) for the charge light to come up. Make sure you're waiting at least 10mins before trying again.
Yes tried that i think the charging bit in the phone has had it as the usb cable does not fit snuggly in the phone socket
Its a faulty usb port and motherboard, there hv been a few post about it, it happened to me. If u live in usa you are screwed if not sony seems to replace it in few weeks. I have an x10i and sony has had my phone since June 5th. I live in usa so since the I version not released in my native country im having.trouble. Good thing I have other phoness
