Boost Force..
sinisterfox
Member
I know its made by ZTE but can anyone give me a model or whatnot so I can do some searching....everyone is ranting about the HTC not so much bout the ZTE
We went thru a bad update with sprint so I am glad for one this phone will not get any updates and It appears that it is also a Virgin Mobile too.
This phone may get updates because ZTE's new approach is to please its costumers so keep your fingers crossed for JB (not likely but dreaming doesn't hurt lol). As far as Dev support, this phone is on two carriers which will allow for a wider range of attention towards this phone, especially due to its price and features. Let's not give up on the phone so soon, it takes time and patience before we can see any change
Purchased the phone today and i gotta say its great! The phone speaker is awesome and loud!! Great features and execllent preformance! I wanted to get a new phone to get music again due to last phone incident... sadly i am very very disapointed with this music player on the phone. It isint as loud as all the other phones when you plug headphones in. Outside speaker is great but listening to audio and music especially is waaaayyy to low. Please android makers do whatever you can fix this low volume problem with headphones A.S.A.P!! Its not the headphones! Its the phone ( Boost force ) please fix!!!
Try downloading Fusion Player, it does just about everything you'd want it to. I too had the low volume issue but Fusion turned out to be a fix. Tell me if it works!
Thanks man for recommending the Music player! Didnt really fix the volume problem through my headphones :/ it did boost the bass just a tad. But its a great player and its gonna be my favorite now lol thanks for the help and the player! Sure hope they fix the volume issue for headphones in an android update. Itd be helpfull! Thanks alot man!
No problem
I've been on the Warp for over 2 yrs and was very happy with the hardware as well as the dev community and have been a tester on many roms for it but sadly I was pressure washing and killed my touch screen in the process...and am now back on my prevail (what a downgrade XD) any opinions on warp...warp sequent or force as a replacement? I did love my warp and it's only gotten cheaper....I'm at a loss.
Wow I think pressure washing your phone is a little extreme to get it clean, but hey my wife is a finatic about cleaning. j/k
Not sure if I understand your question tho. I find the Force is a good quality phone for a budget price. It's not a Evo or GS# but it Does exactly what I want and need such as;
Watch movies that I dl to it.... hint Rock Player lite for avi's
Hotspot for vacations
ICS for the reason that JB wont let me use my HTC custom keyboard.
:smokingsomb:
My girlfriend has a War Sequent and I have a Force, my last phone was a Prevail. The Force is a huge upgrade in every way from the Prevail other than the options after rooting...but it is a newer phone. My girlfriend seems to have some glitches in apps with her Sequent that I don't experience. Also, both of our front cameras as flipped in most apps, but mine seems to be fine with Skype whereas hers is unusable. Force has better specs, Sequent has a slightly bigger screen.
I think you can replace the digitizer (touch screen) for about $30. I saw this on ebay the other day.
I wish I could recommend one of the ZTE phones you've mentioned, but I'm staying away. The support is pathetic, go to HTC or Samsung.
Download Equalizer App!!That will get the mic pumping!!!
