Root [Boost Mobile] 3g keeps turning off..HELP!
mikegmoney
I am running the latest alienwarp rom along witg the 3.0 kernel.for some reason 3g will turn off for no reason,out of nowhere.at least once every 30 mins.it will either come back on by itself or if i switch back and fourth to evdo only.somtimes it will come bak on if i switch the vocoder to evrc or 4gv.ANY1 have any ideas?im lost..i have wiped and reflashed a couple times now.even flashed a couple other roms too and it will be ok for bout an hour and start doing the same again..if somebody could give me some ideas it would be great...THANKS..
Might be something in the build.prop causing it, post three or four of the glitch kernel mentioned a line that causes issues if I recall w
