Seem some peeps in xda had gotten ota
Jdsingle76 says it doesn't distinguish between Boost or VM basebands so it should work with both. I've been keeping an eye on him for a few days now. It's looking good since Samsung released its source and he's been working on it.:thumbup:
Thanks for keeping AF updated @wetbiker7. Keep checking XDA bro, I'll update as things progress.
There is no worry about Knox on my build, because I deleted the bootloader from the update.zip. Additionally, if you flash the App remover from the XDA OP, you'll get rid of the rest of the crap that's in there related to Knox. Glad it's working for you @bshunt29. It is pretty sweet. And @johnbobie, if you installed with Kies, you are now stuck on 4.3, because you can not downgrade, nor can you flash custom roms. If you try, you'll most likely brick and have a very expensive paperweight. And no change is needed to any update script, just flash from the OP and enjoy![]()
happy thanksgiving!:thumbup:You're not the first I've heard say this... did they block download mode? If not why can't we just odin back to stock md7, it has all the partitions?if you installed with Kies, you are now stuck on 4.3, because you can not downgrade, nor can you flash custom roms. If you try, you'll most likely brick and have a very expensive paperweight.
Ok, I have a few questions I'm hoping someone can clear up for me. First off, I am on Boost mobile with rooted and running a custom 4.1 rom. I have tried flashing two different 4.3 custom roms and everything works good except my data. There are times when I don't have data (right after flashing) and then at times I do have data but when I turn my wifi on and then when I go out of range of my network, somehow it messes with my data and I have no data. This is why I am currently on a 4.1 rom.
My questions are, since this update (4.3) by boost, sprint is out, I know were not suppose to take it being rooted and running a custom rom but do the developers of these already created custom roms have to incorporate this update into their roms or do they need to start from scratch to build another rom with this update in it?? I would like to use a 4.3 rom as my daily but the custom roms I have tried I am having issues with. I have seen some posts where there is a stock version of this update out. Does this stock version have all the knox files gone? I really like a couple of the custom roms but I have tried multiple times to use them with the same mentioned issues. If this update is incorpoated into these roms, I certainly would be willing to try using them again, maybe the update would solve the data issues I'm having on 4.3 roms. If anyone can shed some light on this it would be greatly appreciated.
