Root [Boost Mobile] All failed
cornelljdavis
Every sms I send fails immediately upon pressing send. Mms works great howeve sms doesn't. It was working great for about a week and randomly stopped. This is the 3rd different aosp rom I had this happen to me with within the last few weeks. Anyone have a fix or can help out is highly appreciated. Also btw I did flash the universal apn fix in this forum and it works however like I said its only working now for mms not sms.
Hmmm. No SMS? Carrier issue maybe? I don't know.
The 1st thing I would do is try Chompsms. Make sure you disable (uncheck) notifications in the stock app 1st before making Chompsms your default.
If that doesn't work, try flashing a stock ROM and doing a profile and prl update. Make sure you've got SMS, then flash the AOSP ROM you want. If you don't have SMS on stock based TW then your carrier may need to reset it on their end.
Edit:
If you're using Greenify, make sure you haven't Greenified it.
