They haven't released the stock rom and no one ever made a flashable backup so unfortunately we don't have it yet I'll probably get around and make a flashable stock zip no promises though
I figured not... a zip would be a great start, thanks for any development. However for me cwm and twrp wont work for any options other than reboot... I will be waiting.......... it and or something will come
yup, i did specificly try to fix permissions... not one fuction works on ether cwm or twrp other than reboot to system and reboot to recovery... i cant even factory reset from cwm or the main system from options because when it reboots to do the wipe it uses commands from the recovery to do it... yes I've flashed recovery about 10 different time and re-downloaded it about five times in case i got a corrupted file while downloading. i had to obtain root with the sgs3 toolkit and use the sprint unsecured boot.img
