Root [Boost Mobile] Boost ZTE Warp, SD music transfer to Internal
Hi all. I have a question. Just got the ZTE Warp from Boost, and 80% of my music is available to listen to but three albums that are available to listen to, track by track not full album at a time, are only located on my SD I found by going through 'my files'. How can I transfer the 3 albums onto my internal or something so I can listen to ALL my music on one music player??? I'm so frustrated :confused:! Thanks in advance! :D
moving them to your internal is easy enough, but you have to keep in mind you only have a very limited amount of internal storage and if your storing 80% of your music there already you've likely filled it.
You'd be much better off storing your music on your SD card or in the cloud and swapping to a proper player instead of the stock one.
i have albums that are located on my sd card, but only some of my music is available to play on the two music player apps that came on the phone itself. If i got a new music player app would it enable to me to play all music including the albums then? I dont mind not putting the albums on the internal but i do mind not hearing them..
