Root [Boost Mobile] Can Nd8 based roms be run with the ndc bootloader?
Modman
Just curious because they are both kitkat bootloaders.
on the boostsgs3 which one is better to use?
Yes they will work fine. There's pretty much no difference between them unless you want to run stock and have a working built in tether/hot spot functionality. Then you need ND8 since NDC doesn't have the correct code.
