Snake X
Android Expert
Well I decided to step up to the plate and buy chainfire pro so I could do some THD testing
As you may or (probably) may not know I'm interested in fruit ninja THD in some of my posts. So that one was the first I tested
And it works! I'll edit this post with screenshots and everything with all the free THD games I test (which may be a while)
But for now, I can confirm fruit ninja THD works swell with the occasional lag (and sometimes pressing menu button is required to unlag it.. which is weird lol).
Though the text is a bit small (like the "combo blitz" that shows up) or something of that manner. You can really tell the difference!
Again, thread is WIP!!
Heh.. I also officially hit 0 Bytes free on my stock SD card so i couldnt use some of the apps that require like 500 MB so I'll be tomorrow going to bestbuy or newegg if bestbuy doesnt have reasonable pricing on it. So that's why the delay.
edit: soulcraft doesn't work. I've tried different options/configs.
edit:
- sprinkle works (though best without chainfire)
- zen pinball THD doesn't work
- shadowgun THD doesnt work (requires tegra 3 cpu)
- skyrim live wallpaper works
- galaxy on fire 2 doesnt work (crashes after splash screen's)
I WILL MAKE SOULCRAFT WORK DANGGIT.. lol
edit:
