AnDroiDHackxr
Does it exist/is it in developement, I prefer Cyanogenmod over stock android and I really want a CM12 rom for my phone, any info is greatly appreciated
Thanks for the help, yesterday I did some searching on Google and found this ROM and since then I have flashed it. But thanks anyway for the help!
Is everything else working too? LTE, camera, etc? Are you using Sprint? And can I flash CM11 M10 now that I'm on OA3 baseband?Thats probably as close as youre gonna get for what you asked bro. There is also a working kernel now too. I dont know if he made a lollipop one too but I just flashed todays DKP triband build to CM11 m10 and my rotations finally fixed.
LTE works, camera doesn't, to fix the camera problem download open camera from the play store. And yes u should be able to.Is everything else working too? LTE, camera, etc? Are you using Sprint? And can I flash CM11 M10 now that I'm on OA3 baseband?
