Root [Boost Mobile] Disabling samsung toggles in notification
alpha2k
Android Expert
Just wondering if there was a way to disable or get rid of the samsung toggles at all, IE: not have any in the notification pull down area.
Before anyone asks, because I'm sure some people will wonder "Why would you wanna disable those" well simple answer would be disable the samsung notifications, and use another app for notifications. There are many out there 2 I can think of are AnTek Quick settings and Power Toggles.
What ROM are you on?
I am on the conquest ROM and the way moonknightus set it up there is a notification panel and a separate quick settings panel.
Not sure that this helps you though.
I'm on stock rooted with towel root.
Bro, you pretty much can't to anything with stock. That's why it's called stock. Unless there's an Xposed module that will do it, you're stuck with what you have.
I did try with Conquest and there is no way that I've found to disable the toggles. As I mentioned, there may be an Xposed module that will remove the them. Look through the module list and see what's available.
