If the devs are interested, I can go out today and pick up some film for my canon eos rebel s, and can try to get some hi-res pictures taken of the mobo. It'll just take a day to scan them in. Any takers?
YES!!!!
Well, I got pictures, as best I could. I hope they are high enough quality. I also wrote down the numbers on each "block" like ram and processor and stuff. There were hidden blocks under the metal backings as well :hmmmm::hmmmm2::thumbup:. I can't wait to develop them and have you guys find out.....
So, learned that I need to use flash when I use my film camera...never really done it before. However, I do have at least 2 salvageable photos...I'll have to disassemble and retake photos. Sorry!
See Below:
On the photos where the metal shield on the front part of the motherboard (not the camera side) is removed, you'll notice a metal cover that seems like it shouldn't be there. there is indeed a chip under that of some kind, maybe just a transistor, and one on the other side as well. Also, sorry about the poor quality I'll post the numbers and letters for each block when I upload the others.
WAIT. My best friend will be coming on shortly to post a link. That link will bring you to his photobucket, where he used his S3 to take some ridiculously high resolution photos of everything I took apart. I hope they provide what you, I, we need to get this worked out!
Give'm a couple minutes.
Hey guys! Hope this link helps! It's a photobucket album of some pretty good pictures! If you click an individual picture to bring up it's page there is a magnifying glass on the lower right of the picture click that (and then again for some reason on the next page??) to bring it up in full size.
Hope this helps!
ZTE Warp N860 Photos by daf-man | Photobucket
Vincent
Did you get a look at the hidden blocks under the area I cut away? I personally am curious what they are. If you look back at the not-so-good pictures I got, you can see the metal panels. Cool that the storage is standard!
Yep, I'm in the middle of running the numbers on all of those chips. So far I have about half of them discovered
The important thing to note here is the presence of the QTR8600... this is in fact the chip which provides RF transmit and receive! So, now that I'm fairly certain that we have the chip... what are we gonna do about it?
Hey, one thing... I think the Hynix chip is layered on top of another. Is there a way you can separate them and get a photo of the underlying one?
I would rather not dissect my ram, as my phone is perfectly functioning even after two of the previous dissections (rather not test my luck XD)
I did a little browsing around, and I'm fairly certain that the memory is low power ddr2, and mcp. It could potentially be replaced by 8 gig of ram if that is the case! (Page 8/12 of the Hynix 1H12 handbook).
a quick search of H9TKNNN4KDMP, results in this page: SK Hynix H9TKNNN4KDMP > Device Library
Also Merc, most of your links don't work on that post you made.
