Thank you so much! Do you have any idea where I can get a boost 4.3 firmware ROM? I appreciate your help so much!There are stock ROMs you can flash that are 4.3.. No sense trying to go back to complete stock (recovery and all) to take the update when you can easily flash a 4.3 rooted ROM. Just my opinion.![]()
1) TWRP replaces the recovery firmware, it doesn't root the phone.
2) Odin is a technician's tool and, like most technician's tools it has no safeguards built into it and relies on the knowledge and the experience of the technician to prevent errors. You can use Odin to do anything to the phone, except damage the actual hardware. But you can totally wipe out all the firmware.
And it's not the way to root a phone.
3) "Return to stock" really doesn't mean anything in the way you're using it, because there's nothing to return to. It's not like turning the page of the book back to return to the words on the last page. You made permanent changes to the phone - you can't "unmake" them. You'll have to find a flashable ROM of the stock firmware and flash it. (I'm afraid that any more fooling around trying to fix things, even if you think you're following the directions carefully, will just result in more damage.)
Permanent, as opposed to "just flip the switch and it "reverts to" the older <whatever you flashed>. People don't understand that flashing a recovery or a ROM wipes out the original - there's no "returning to", you have to repeat the same process with what you want to "return" to. (I try to fit my answer to the apparent experience level of the person asking the question. More experienced and knowledgeable readers, such as yourself, may notice a simplification that makes the answer technically correct, but a hex dump of the code to fix his problem would be useless to him.)Additionally, he did not make permanent changes to his phone.
Even that can be, if there's no hardware damage. (Not always with software - it sometimes takes hardware to stuff firmware into a totally hard-bricked device. At very worst, even a 2 byte tight loop can be fixed with a CPU emulator.)Anything you do short of hard-bricking beyond repair can be undone
Yeah, well ... The more stupid the idea, the longer it takes to figure out how to get rid of it. But you CAN flash ROMs to the AT&T and VM GN3s now. And Samsung has admitted that Knox has a security hole you can drive their building through.except getting rid of the Knox bootloader(for now).
