Root [Boost Mobile] Help??? What should i do MEID
NitroGeek
Member
Ok When i got my Warp And i activated it ... it was working fine. But then i deactivated it and changed the rom but now i want to reactivate but i was looking at my MEID DEC # and it was 17 numbers long not 18 should i worry. OH and i pulled out the battery and looked at that number in the back and that one had 18 numbers
When you go to reactivate the phone, you need to use the numbers on the back of the phone. Don't worry about having a non-stock Rom. Boost will never know if you don't tell em!
I have noticed that even on stock the MEID number in the settings is off by a digit. Maybe they did this for security reasons not sure. Both of my Warps, stock or Custom ROM show 17 digits in the settings and 18 on sticker under battery. The only difference i have noticed is they left off a zero on the MEID in the settings, all other numbers match. But you shouldnt have any issue reactivating with the number under the battery.
