Root [Boost Mobile] help
joex
Member
I am using the zte warp and I am experiencing a problem when I root phone.
I always format everthing a few times before i install a rom but When I root sometimes people cant hear me when I talk and I have to clear the Davek cache for the phone to allow me to make calls where people can hear. The phone works great in stock with no problems.
Please help
Please help
Hello joex. That dalvik chache clearing for better functionality tells me that remnants of pre-installed ROMs or perhaps the stock ROM are still being polled for use in the system and conflicts are arising because of that.
You may have to format your internal and external memory RAM and sd card, besides running the recovery "wipe" function. That wipe function by the way should always be done two or three times prior to giving life to a new ROM.
Good luck. Tell us more about how you're getting ROMs into your device and the steps you took to root the device in the first place. ;)
Im using noob V11 rom which roots the phone. How do I format the internal memory and external ram
just to let yu know when you format ya sd card you will erase everything on it so you might want to back it up on ya computer first but not only that sometimes after you format ya card you get a problem with ya sd card not mounting so first make ya pc backup then just do this This is what I did to solve my problem. 1.boot twrp 2. Partition SD card(this is because twrp wasn't reading my SD card. This solved my problem but it wipes all data on your card.) 3.fix permissions 4. in twrp mount USB your phone should work.
