Root [Boost Mobile] internal storage restore
cornelljdavis
Does anyone know how I can restore my deleted internal storage from my phone or corrupted SD card? I deleted my internal by accident through philz touch
Sorry to say but unless you got it backed up somewhere then it's gone.
Even though I'm pretty good about saving backups on my pc. I still lose data once in a blue moon and lemme tell ya, it sux! Especially when it's important things that can be replaced.
That's odd. Because I seen a a few ways to do so. O just wanted to know if you guys knew. Thank you
You can restore deleted internal from a backup bro. Just as you can restore apps and data from a backup without restoring the entire backup. Gotta know what you're doing though. There are rules to what you can and cannot due.
As for a fully deleted internal. It is what it is bro..... deleted. Unless there's something new or different about the S3 that is. If so, I have yet to read about it.
Ok, this might be too little too late but if you haven't done anything to your SD card, you may able to get some data back.
First, down load and install Recuva to your PC
Recuva
Then put the micro SD card to a card reader and put it into your PC/Laptop. Run the Recuca program and scan the SD card. If nothing has been over written, you can get the deleted files/data.
I deleted a back up file from titanium back up by pressing delete instead of restore. I ran the above instruction and recovered my deleted files. This is from my experience doing data recovery in the past. :D
Good luck...hope it's not too late or for future use. :)
internal storage...restore... ok i will try your idea. however my micro sd card i had storage on was corrupted i believe or something because it cant be read by my phone or laptop. the internal storage wipe was a accident by me all because i was not able to get the mirco sd card to read and was in recovery mode and wiped it on accident. i almost dont care but because you took time out of your day to tell me this help me i will give it a try and let you know how it goes.
If your SD card is corrupted that your laptop can't recognize or read the SD drive then you have a bigger issue. You'll need to run some additional steps such as chkdsk, TestDisk (recovery program), and etc. There are a lot of other programs but TestDisk is simple but great DOS program I have used in the past with good results. If the step by step below is complicated try searching on Youtube for how to guide. Good luck.
TestDisk
TestDisk step by step
