I read this on android central
You do this with 7-Zip/WinRAR
Note: DO NOT EXTRACT ROM!
In the ROM go to:
/META-INF/com/google/android/updater-script
1)Open updater-script with a script editor such as notepad/notepad++ (makes things 10x easier), or gedit if you use linux
2)Delete the first line of code (all the way up to the first semicolon you see) and delete the first semi-colon as well
Do not go past the first semiclon when deleteing and DO NOT forget to delete the first semicolon.
Also saw this link http://forum.xda-developers.com/showpost.php?p=31519426&postcount=186
In the ROM go to:
