Root [Boost Mobile] kernels
Im using dkp kernal set at 1782 with the freelunch gov. im using the moar rom. make sure your kernal matches your rom. the ktoonz kernal is also good. look around on xda you will find something
That's what I've always used. I set the settings to 384 to 1724 exit app. When I renter the settings go to 100 to 1100 or something like that every time
I've used both Touch Whiz version of the KToonsez kernel and the DKP kernel.
I've had the best luck with the KToonsez kernel. I've had trouble with DKP and the settings not wanting to stick.
You may have better luck with DKP on the AOSP based ROMs.
When running Touch Whiz ROMs, I've decided to stay with Ktoonsez. It comes with it's own kernel app too, the KTweaker app.
