Right but root Explorer see's the folder fine, I can even browse the files and execute the files. Where the problem comes in is making a new folder, sometimes it works other times it's as if I never even created a folder
It's something to do with Kitkat. I've been reading others with KK and having this same issue and
it also gets affected in the PC side reading stuff as well as well as internal sd.
I'm not sure why or how, but it is like not re-scanning the sdcard, therfore it doesn't show what was just created, or moved, kinda like refresh is broken.
Once I un-mount the sd card, and re-mount it everything then gets seen as it is suppose to, the changes and all.....same goes for the phone internal. I have to re-scan it if I am changing or adding or deleting or creating folders before it gets noticed correctly.
Kinda annoying, but I'm trying to find a work around. We'll see how long I can hold out.
Never noticed this before until now, but then again I wasn't doing much modifying or backing up stuff either.
The scanner apps out now for the lost part don't work with KK, and this is why I am guessing.....their having issues getting stuff to re-scan or scan period and it's a global issue it would seem.
I found a scanner that works for internal sd of this phone, but not the external yet. What would be ideal is if I could "pick" what drive to scan, all with 1 app that would have like a drop down, and let me pick said drive then scan.
This issue was presented early in GB days if I remember right and got fixed with ICS......so again it has presented itself. So far I haven't tracked down an easy fix yet but I'll keep looking.
Could explain why TB doesn't like to play well also.
Would also explain why the 32GB cards and KK roms are having issues as well. All related I'm sure
