Not sure about Liquidsmooth, but on the stock ROM all you have to do is to pull up the picture that you want out of your gallery, hit the menu button and then select "set as" and you will see the option for "lock screen." See if that works.
Try the QuickPic app and see if it allows the option to set the lockscreen wallpaper. If not, try Xposed Framework. It has a module which will allow full control of the lockscreen.
Pretty sure QuickPic will work. It's been awhile since I've ran LS but I'm 95% sure the QP app will work for you.
