Root [Boost Mobile] moving apps to system?
You're rooted right?
If not, you can't do it
If you are, titanium backup could do it, or you could probably just physically move it with a file explorer
with file explorer i tried that and then had to reinstall apps. cut from data/ and pasted to system/app?
yes I'm rooted.
Not sure what the benefit is, but titanium backup lets you make an app a system app... Always check the data data folder and make sure the app doesn't have any lib files, if it does those will need to be manually copied to the system lib folder, otherwise the app isn't fully integrated
